Tractor Talk Discussion Forum
PTO shaft question
JackT
05-08-2005 09:58:13
I have PTO shaft with bad bearings in the U joint. I've looked at farm parts catalogs and see that there are a number of different series of PTO parts 6N, 2N, 14N, etc. and all have the same size bore/shaft ranges. I don't see any markings on my shaft. How do I tell what I have so I order the right parts?
Gerald J.
05-08-2005 17:49:18
 Re: PTO shaft question in reply to JackT, 05-08-2005 09:58:13
There are a couple dozen sizes, and each has at least two variations and then there are metric sizes. Some have retaining rings inside, some are outside. Some have a symmetrical cross, some not. Like said down below, take pieces to the parts store (and some automotive stores have such parts) and compare. They keep a dial or digital caliper on the counter for just such occasions.
The printed catalog from Baum Hydraulics has a good selection of U-joints and repair parts. They do have a web page, I don't know how much is there.
Gerald J.
thurlow
05-08-2005 14:16:33
Is there an equipment dealer nearby? If so, just press the bearings and cup out of one yoke and carry the yoke with you; parts man can match you up..... .....
ejr-IA.
05-08-2005 10:35:44
You have to measure the cross and bearing diameter.This determins which series you have.
JackT
05-08-2005 10:50:52
 Re: PTO shaft question in reply to ejr-IA., 05-08-2005 10:35:44
ejr-IA -- thanks. Any idea where I can find a reference table that will tell me which dimensions/diameters are which series? Again,
Thanks
doogdoog
05-08-2005 12:56:10
 Re: PTO shaft question in reply to JackT, 05-08-2005 10:50:52
Aloha Jack, I found some information on the web about identifying what type of pto shaft that you have. I don't know if it is permissible to posts links so you can email me and I will provide the link to you.
Mahalo,
doogdoog
