Tractor Talk Discussion Forum
Hydraulic jack repair
6N's Short
05-10-2005 12:08:22
I have a Sears 3 ton jack that is low on fluid. There are two flat screw plugs at the base of the handle...one large and one small. I have it in my head that the larger is the fill hole but when I open it with the jack all the way down, fluid gushes out. At it's current level the jack will only lift about four-six inches. Does anybody know the procedure for refilling with hydraulic fluid?
marlowe
05-10-2005 17:48:25
 Re: Hydraulic jack repair in reply to 6N's Short, 05-10-2005 12:08:22
is this a four wheel floor jack if so it has a rubber plug on top of the ram that is the fill hole don't over fill
Dave H (MI)
05-10-2005 18:20:03
 Re: Hydraulic jack repair in reply to marlowe , 05-10-2005 17:48:25
Yessir....four wheel floor jack. I'll look for that plug in the AM. Thank you.
