Tractor Talk Discussion Forum
late 4020 pto
sbr
05-10-2005 18:58:11
I"m working on a late model John Deere 4020. When I engage the PTO and drive the tractor hydraulic oil comes out of the rear most clutch housing. The oil is not coming out of the piston pins that engages the hydraulically engaged PTO. The oil doesn"t just sift,it drips steadily. Does anyone any other ideas?
Anthony Andolini
05-10-2005 19:48:34
 Re: late 4020 pto in reply to sbr, 05-10-2005 18:58:11
Sometimes the bolts that hole the piston plate on, are screwed down too much. This warps the plate just enough for a seep, or sometimes more.
Bob
05-10-2005 19:07:16
Could the casting with the little pistons in it be cracked? I don't recall exactly how the pressurized oil gets from the PTO valve in the dash, down into the flywheel housing, and into the casting with the 2 "apply pistons" in it... could there be a bad "O" ring or oil line in that area?
