Tractor Talk Discussion Forum
Trouble with a beaver and his dam
old
05-14-2005 16:46:18
I have been fight a beaver for a couple weeks now. I destory his dam and in 2 days its back. I don't really want the use the 44 option, if I can help it. I may want him doing it later in the year to hold the water but not right now in case we do get some big rains. Sure wish he would move down about 1000 yards then I would be happy and so would he. Dug his dam out today with my backhoe. How long will it take him this time. Got any ideas of how to stop him with out killing him???
Thanks
Tommy D. - Gotta tell thi
05-16-2005 06:32:49
 Re: Trouble with a beaver and his dam in reply to old, 05-14-2005 16:46:18
Back when I was a kid, early 1970's I believe, my uncle had a large field he leased to a farmer neighbor to grow cotton. His name was Ivan, I'll never forget. Problem was that on one end of the field, the beavers would dam up a stream and take almost an acre of the field with water.
After getting his BIG John Deere stuck twice, he decided to do something. Went to the hardware store and bought a bunch of dynamite (TNT or whatever it was - you could do that back then) to blow up some dams and reclaim his field.
Anyway, apparently he had never used explosives before. Of course, myself and my cousin HAD to go watch this as stuff was gonna get "blowed up"!
I remember he put about 8 sticks together in a plastic bag, put a blasting cap & fuse in the center stick, and trodded off into the new swamp to place the explosives. In a few minutes, he came trotting out again. We were prolly 100 yds or so away, behind the pickup. After a minute or so, it went off. I remember the shock wave almost knocking us over, and a tree stump the size of a car 100 feet in the air! Then we realized that the air was full of sticks, clumps of mud, etc., and all that stuff was about to rain down on us! We ran up into the woods as mud, sticks, fish, etc, literllay rained everywhere. A log the size of my leg landed on the windshield of his truck cracking the glass! And it left a huge crater where the dam was.
As we were standing there in the aftermath, my 10 y/o cousin looked up and said "Damn Ivan! I believe you used too much!"
Real funny at the time, but it scares me as I look back at it. After that, he found that 1 stick was sufficient to remove a dam.
Tommy D.
Coldiron
05-15-2005 05:09:28
Old, Listen to Dell and check your previous post on beaver, I went into length on the method he mentions. It works !
Dell (WA)
05-15-2005 00:01:43
Old..... ..depending upon the size of yer stream (and most beavers don't dam big fastwater streams) MAKE A SIPHON outta a long 2ft dia culvert in the form of an "L". The upright part will allow YOU to set the beaverpond depth and iff'n you guard the top, the beaver can't do 'nuttin' to make the pond gitt deeper. Place the long part of the "L" under where the beaver is building his dam and he'll just build right over-itt. Again, depending upon the size of yer stream, you might need to install several siphon's (side-by-side) to handle the water volume. But you can eyeball that 'cuz yer there. (look down stream in an un-dammed section to gitta idea of culvert (siphon) area you need to handle usual water flow volume. Most culverts are designed to be 1/2 full under normal water flow volumes. Simple, eh?
and theres nuttin like flyfishing a beaverpond..... ...Dell
Too Far Gone
05-14-2005 22:31:15
Hey,If you could find some old TNT,and watch the movie"CADDY SHACK"for a few ideas,well I bet we could blast'em out for good if you catch'em at home.
lzybull
05-14-2005 19:49:56
put a culvert in the stream. they will build around it,but won"t plug it. has worked good for me and my dad. Glenn F.
KirkMN
05-14-2005 19:14:41
Tie a plastic milk jug to a stick in the middle of the channel where the dam was so the jug moves with the action of the water. They will usually move. Might just be enough to be out of your way.
Les
05-14-2005 18:52:16
Beavers react to the sound of water. Anything you do that contributes to the sound of flowing water will spur him on to action and he'll want to "fix the leak". I have seen where the level of water was lowered by putting in a piece of culvert and keeping the beaver away from it with wire mesh. You'll have to keep right after that, though. I'm not sure which of you is the most persistent but I wouldn't bet against the beaver.
James2
05-14-2005 18:43:37
Sounds like eliminating the food source could be a good way to go. Unfortunately we couldn't consider this option because there were too many trees. Alternative is to live trap them and move to another site, although on occasion we have had to resort to the last option you mentioned. Trapping can be tricky and most states require a permit. Best plan is to find an experienced live trapper.
Bill Drew
05-14-2005 18:26:15
Beaver move on when they run out of food behind their damn site. Some logging/brushing/wraping trees with hardware cloth might speed up the move.
edchainsaw
05-14-2005 21:43:24
 Re: Trouble with a beaver and his dam in reply to Bill Drew, 05-14-2005 18:26:15
well the backhoe helped around here... it moved them both directions up and down the stream.. after tareing the dams out several times they got tired and moved a bit...
these beavers use corn so that food source is going to be there a while---they even tried to dam up the Eel River with corn stalks
wizard
05-15-2005 03:12:39
 Re: Trouble with a beaver and his dam in reply to edchainsaw, 05-14-2005 21:43:24
Did the last resort last year. this spring I"ve got two more. gave up and letting them eat themselfs out of food. First thing they did was plug a 33inch sluce several times so ... they are even starting another dam down below. lots of ducks.
