Tractor Talk Discussion Forum
Hours on a tractor vrs Miles on a car
Canadian
05-16-2005 15:19:20
I would like to get some opinions on tractor hours by guys who own tractors. What is high hours on a tractor? I have a 3 cylinder gas tractor with a ford 175 CI engine which has approx 4500 hours. The tractor starts and runs great and 99% of the time you cannot even see smoke!
Is this the norm? How about diesel engines as well? What is considered HIGH HOURS?
Thank you, Kindly
The Canadian city boy in the country!
Mike M
05-17-2005 05:26:26
 Re: Hours on a tractor vrs Miles on a car in reply to Canadian , 05-16-2005 15:19:20
Maintenance is the key. I have had some high houred tractors that were better than low hourer ones. Also if proper repairs were done when needed a high hour tractor could have alot of new parts.
Rod F.
05-16-2005 19:46:18
I'm guessing that by the engine, you have a Ford 3600. The 3 cylinder Ford engines were actually designed as diesels, and in the case of yours, converted to gas. Yours was designed for a 10000 hour service life, and there are LOTS that did that. If it's running strong now, with proper care it will last a long time. BTW, I'm not disputing what Allan has stated with regard to service hours. As a generalization, he's dead on. I know that most Cummins and Cat engines today have an expected service life of over 15000 hours before any major service work. Take care.
Rod
Canadian
05-17-2005 07:31:18
 Thanks Rod in reply to Rod F., 05-16-2005 19:46:18
Actually I have a ford 335, Industrial with a 3pt hitch and pto as well as a loader. I've heard that it was the same as the diesel engine except for the head and compression ratio.
Anyways I'm nearing the 5000 hour mark, and it doesn't even burn any oil yet? It was a countys tractor so I have heard that they do regular service on their equipement.
Hugh MacKay
05-16-2005 16:08:41
You have some good figures from Allan. My experience with 20 tractors over the years bears out what he has said. If you wish to compare Kilometers to hours, here is an example. The Mack truck I drive has aprox. 11,000 hours. The Km are close to 650,000 roughly 400,000 miles. I may be off as truck is on second speedometer. It shows 214,000 now and I understand old meter went at 440,000 Km.
Allan in NE
05-16-2005 15:50:10
Hi C,
Generally speaking, 5,000 hours on a gasser is at the outside limit.
Diesels are hard to judge. Most will agree that 10,000 hours is an average life; but many go 17 to 20,000 hours.
Allan
