Tractor Talk Discussion Forum
no fire
maryd
05-17-2005 13:19:51
my husband bought an old f-cub tractor and he can"t get any fire to the coil can anyone give us any ideas?
dr.sportster
05-17-2005 18:26:28
 Re: no fire in reply to maryd, 05-17-2005 13:19:51
Whats these guys said and; as in all electrical troubleshooting start with a fully charged battery.
TomH
05-17-2005 17:05:32
If it has a coil it better have a distributor :^)
Disconnect the low voltage wire coming out of the coil and see if there's any voltage going in. Then connect it (and make sure the points are open) and see if you have voltage on the other side. Then see what happens when the points close (should drop to near zero volts). Chances are there's a bad connection between the battery and points, or the points aren't making a good contact, or the condensor is bad.
Weirsdale george
05-17-2005 16:38:41
First we need to know is it a distributor or magneto ignition?
SJ
05-17-2005 16:53:32
 Re: no fire in reply to Weirsdale george, 05-17-2005 16:38:41
Yup that be good to know.lol.
SJ
05-17-2005 16:32:40
Try changin the condenser and or points if you already havent.
Good Luck
Stan
