Tractor Talk Discussion Forum
Removing tractor tire...Help!
Dug
05-21-2005 11:02:50
I am trying to replace a broken wheel on a JD 2510. I have taken the three bolts out of the center and tried to drive the two bolts in to "push the wheel off. It's not working very well! I need some advice...
Thanks,
Dug
Don L C
05-21-2005 19:18:30
 Re: Removing tractor tire...Help! in reply to Dug, 05-21-2005 11:02:50
I dont know what a JD2510 wheel looks like.....I have a FARMALL "M" if you have seen them.....I loosen the bolts enough the wheel could slightly move.....then in low gear slowly drive the tractor applying and releasing that wheels brake.....that has always worked for me.....on a FARMALL the axel has a grove in it...jack the weight off the wheel, place a jack stand under the tractor...turn the wheel until the grove is at the top(12 o'clock)....using a engine puller and a chain...slightly lift the weight off axel...wiggle the wheel bach/forth and at the same time have someone rolling the lift back until the wheel clears the axel---- be very carful,if the tire is loaded with water drain befor starting..... ..good luck,don
