Tractor Talk Discussion Forum
Allis Chalmers 7000
Hurst
05-23-2005 07:29:41
Did this tractor have a standard 2 speed pto or just the 540? Would it make a good tractor for PTO work, such as batwinging, baling, discmowing, teddering, etc.? I understand that the 7010 is a better tractor, but with my budget I can't quite afford one of those. I am looking for a dependable, reliable, easy/inexpensive to work on, and functional. The tractor is a nice looking black bellie, but not sure what type of tranny. Any input would be appreciated. By the way, the most tillage it would probably see would be a 3-16 mounted AC plow and a 11 ft disk. Also, what should I look out for on these tractors for both powershift and powerdirector? Thanks.
Hurst
Val
05-24-2005 10:17:17
 Re: Allis Chalmers 7000 in reply to Hurst, 05-23-2005 07:29:41
If it has the black belly it is the late model. Most of those have the power shift. The early models had the power director. Both are good reliable transmissions. They have dual pto speeds and a good cab. Would work well for you if in decent condition.
xdonxx
05-24-2005 02:57:25
pto shaft unbolts turn around for 1000 rpm.good cheap hp.
