Tractor Talk Discussion Forum
Allis Chalmers 5020 starting
R. Cox
05-24-2005 19:45:01
Having strange trouble with my AC model 5020 not turning over. It was running and strating fine. Shut it down. Went out 20 min. later- nothing. Checked switch, battery, & starter. All wires on switch seem to be connected. Cleaned battery post/cables, then even changed battery. Still nothing. Pulled starter/solenoid, had them checked out- OK although it had a good bit of fine dust inside (dirt, grass from mowing). Remounted the starter today and when I tried to reconnect the positive cable to battery, the starter whines and trys to start even though the key is not in the switch and the switch is not on either. Very strange, huh? Any ideas?
Robert in TN
05-25-2005 00:30:23
 Re: Allis Chalmers 5020 starting in reply to R. Cox, 05-24-2005 19:45:01
I have a 1982 model 5020. About 15 years ago it would not start from the key switch. It just acted like the battery was dead. I changed the battery but nothing. I jumped the solenoid with a screwdriver with the key on and it started. Since then, I had the starter rebuilt and installed a new solenoid. Actually, 2 solenoids. It still does not start occasionally. I just keep a screwdriver on the tractor and when it will not start I jumper the solenoid. I just do this once and the key switch will work. Good luck...
