Tractor Talk Discussion Forum
JD 750 compact tractor loader backhoe
Bubalee
05-25-2005 00:03:29
Howdee, Will the loader and backhoe off an older John Deer 750 (Yanmar) fit on a 2000 John Deer 790? Thanks, Bubba
Mydeere
05-25-2005 17:55:11
 Re: JD 750 compact tractor loader backhoe in reply to Bubalee, 05-25-2005 00:03:29
The loader for the 750"s was a model 67 which had a dual spool valve mounted to the loader frame upright where as the model 70 loader for the 770 and 790 uses a tractor mounted scv. I don"t believe you can get the mounting kit to attach a 67 loader to a 790. The backhoe will work if it is a model 7 but will require different subframe brackets to mount on to the 790.
