Tractor Talk Discussion Forum
oil pump
honda
05-26-2005 18:10:56
i have 1950 john deere b.the oil pump isn't pumping oil.i took the cover off and found out that the gears spin freely.are they sopposed to?
thanks bman
old
05-26-2005 19:07:51
 Re: oil pump in reply to honda, 05-26-2005 18:10:56
I* agree you broke the copler not to bad to fix. Costs around $5 give or take a little. It can be a pain to put in, easy if you have 4 hands.
greenmech
05-26-2005 18:29:00
Your oil pump coupling is most likely broken. Need to drop pump to replace. This happens in cold weather when you have water in the sump. Ron Mn.
