Tractor Talk Discussion Forum
In your tool box.....
Mike in UP of M
05-28-2005 19:17:35
What tool do you find yourself using the most to repair or restore old tractors? The tool I use the most is a 6" wire wheel on an electric motor that is mounted to the work bench. It works good to clean up rusty bolts and small parts before painting.
Indydirtfarmer
05-30-2005 11:00:53
 Re: In your tool box..... in reply to Mike in UP of MI, 05-28-2005 19:17:35
5 lb. dead blow hammer with replaceable rubber "faces". If it doesn't fix anything, the sight of me wielding it keeps the wife, kids, and dog outta the shop.....
MarkB_MI
05-30-2005 04:43:05
A pair of 4 inch Vise Grips. Great for grabbing stripped out screw heads and rounded-off bolts and nuts. Small enough to get almost anywhere.
John S-B
05-29-2005 21:19:43
A cold beer for when things just are'nt going right.
John M
05-29-2005 05:57:15
1/2,9/16,5/8 wrenchs,sockets and impact socket!I have about 10 of each,just cant seem to ever find any of those when I need them! ;>)
Don Wadge
05-29-2005 06:53:50
 Re: In your tool box..... in reply to John M, 05-29-2005 05:57:15
John, I'd have to agree with that, or those same sizes in flat and sockets. Those are my most commonly used wrenchs.
John M
05-29-2005 09:34:04
 Re: In your tool box..... in reply to Don Wadge, 05-29-2005 06:53:50
I often find myself needing two of them at a time,and cant for the life of me find them when I need them,or they are in my way when I dont! OR even worse, my kids have gotten in to the toolbox and lost them, so when Isee a deal on those or any other tools I grab it up!
Weirsdale George
05-28-2005 22:25:44
Something that I have that I don't use very much but are indespensable when needed -- gear pullers. Over the years, I have collected all sorts of pullers (probably 20 or so) from very small ones up to ones that will span 18". They include steering wheel puller, harmonic balancer puller, and even battery post terminal puller. I even made a special set of jaws to pull the brake drum on a Model T Ford transmission.
kraigWY
05-28-2005 21:38:30
Air Compresser
Kevin in OK
05-28-2005 21:21:27
A pair of vice grips and an old flathead screwdriver.
Kevin
old
05-28-2005 20:50:34
Tranny fluid, works as good as PB and also works as good as Marvel M oil and cost a lot less. that and a pair of vise grips
kyhayman
05-28-2005 20:35:54
Gerber multipliers, but on my belt, not in the tool box.
2x4
05-28-2005 22:17:39
 Re: In your tool box..... in reply to kyhayman, 05-28-2005 20:35:54
SOG paratool (leatherman-type belt multi-tool)
mattd
05-28-2005 19:40:57
my trusty can of pb blaster...
matt
