Tractor Talk Discussion Forum
Toe-In on a standard wide front tractor ?
Alberta Mike
05-31-2005 21:30:05
Putting the front end stuff back together today on my Case V and I know that tractors should have some toe-in on the front end. This one has 15" front rubber, standard wide front. How much toe-in should there be (or how much closer together should the fronts of the tires be than at the back)?
Van in AR
05-31-2005 22:24:36
 Re: Toe-In on a standard wide front tractor ? in reply to Alberta Mike, 05-31-2005 21:30:05
About a 1/4" seems about right/
Van
Ray,IN
06-01-2005 05:01:45
 Re: Toe-In on a standard wide front tractor ? in reply to Van in AR, 05-31-2005 22:24:36
The shop manual for Harry Ferguson says "0"-"1/4"), measured at spindle height. What is not said is that you must use a long straight-edge to first adjust the front tires so they are parallel to the rear tires so the steering will not pull to one side.
