Tractor Talk Discussion Forum
inherited Tractor, need more info in it, please he
Adam Towl
06-01-2005 13:31:15
third party image
Hello, I just inherited this tractor from my grandfather. I was under the immpression that it was a model T tractor conversion, but the logo says overland 6. He converted it himself a long time ago. It"s been parked in a barn for over 50 years now until now. Any help would be appreciated. I pulled a VIN number off of the engine, A1473640. The front wood spoked wheel"s have "whippet" hubcaps. I would like to restore it to it"s original "tractor" condition for showing.
Bus Driver
06-02-2005 10:01:32
 Re: inherited Tractor, need more info in it, pleas in reply to Adam Towl, 06-01-2005 13:31:15
Definitely a Model A Ford engine. You have part of the optional exhaust manifold heater assembly. The missing top cover had a flared front to catch air from the engine fan which then blew across the fins on the manifold and went through a hole in the firewall to really toast the feet of the front seat passenger. There was a rotating cover over the hole that could be closed in warm weather. If you need instructions on ignition timing, just ask.
Adam Towl
06-01-2005 21:28:11
Thanks for all of the great info on this... I think I will take the "getting it running" option. Get it running, clean it up, but keep the "dings and dents" for stories and such. My next question then is I've never worked with wood spoked wheel's before. Is there a company out there that can refirbish them?
Ratchet
06-01-2005 21:33:21
 Re: inherited Tractor, need more info in it, pleas in reply to Adam Towl, 06-01-2005 21:28:11
There is an Amish wheelwright here that will do them.
sammy the RED
06-01-2005 19:58:28
Nice ! ... Fix her up and put a nice coat of IH-2150 on it. ;o]
Leroy
06-01-2005 18:25:32
The overland radiator probably has a larger capacity and was used to get more cooling capacity and it was Oakland that became Pontiac
Coloken
06-01-2005 17:07:26
If that is the distributor on top, then it is a Model A Ford. Nothing else in the world like it. I second the idea of get it running but do not paint it. I like it just the way it is. (fixed up that is).
Weirsdale George
06-01-2005 17:05:08
The rear end looks like it is out of a Model TT One Ton Truck.
I vote that you do the minimal amount to it just to get it running and drivable. No paint, just leave that great rust patina. Remember there is only one of what you have there.
Maek - IN.
06-01-2005 15:37:50
I'm not familiar with it, but the sheet metal looks good, looks all or mostly there. She's a dream. Take her apart, sandblast, clean and paint her, put her back together. She's a parade tractor if I ever saw one.
Mark
Alberta mike
06-01-2005 15:35:36
Very nice .... VERY NICE (I'm yelling I know) !! Might I make a suggestion? Keep it as it is, get it running and do minor work like carb overhaul, wiring, detailing, minor repairs, etc. but leave it as it was when your grandfather parked it. All of those little dents and scrapes have a story behind them. That way I think it will mean more to you and your family and will probably even attract more attention at shows. A nice little poster with the story of the tractor (or as much as you can piece together) would go nice with it as a show. you're a lucky fella to have it.
Bob N.Y.
06-01-2005 15:28:20
If I remember my history correctly, Overland became Pontiac and Whippet was a Willys product.
Redmud
06-01-2005 16:03:06
 Re: inherited Tractor, need more info in it, pleas in reply to Bob N.Y., 06-01-2005 15:28:20
Bob, Overland and Whippet were both owned by John Willys. They were built in Toledo Ohio, Overland was a Willys Overland product untill the last one came off the line.
Bob N.Y.
06-02-2005 19:27:31
 Re: inherited Tractor, need more info in it, pleas in reply to Redmud, 06-01-2005 16:03:06
Now that I have thought about it some more, maybe it was the Oakland that became Pontiac
Redmud
06-01-2005 14:03:15
Adam, the engine and trans,are model "A" Ford, radiator is Overland, wheels look Overland also. And you need to get that little bugger going..
Sloroll
06-01-2005 13:38:08
That is just too cute! It is a conversion made up from several autos. I suppose it was some kind of kit origionaly but heck who knows! (Maybe someone) I think as long as you use old car parts you will be fine in however you restore it. I doubt if anyone out there will be able to refute your work.
Delbert from Lincoln
06-02-2005 09:10:59
 Re: inherited Tractor, need more info in it, pleas in reply to Sloroll, 06-01-2005 13:38:08
Neat. For whatever it is worth, that engine is difinetly Model A Ford, 28 to 31. From what I can see in the picture you have a worm driven differential, like was used on the Model TT Ford trucks, and on the 28 and 29 Model AA Ford trucks. Those may be Model TT rear wheels. If so the original tires were marked like 32 X 6, or 30 X 5 or some such #. Different marking system. First # was outside diameter, and second # was rim to tread, so they would be 20" tires and are still available on some of these places on the internet that sell tires for antique cars.Best luck with it. I like the idea of just getting it going and show that away.
