Tractor Talk Discussion Forum
changing my blades
Joe1
06-01-2005 15:03:51
Recently acquired a LT14H331KV tractor how do i change the blade?
Andy
06-02-2005 08:40:55
 Re: changing my blades in reply to Joe1, 06-01-2005 15:03:51
Maybe you"re looking for model LT140H331KV? A Snapper LT14H33 tractor? Try the link below and make sure you don"t have a popup blocker on. It will give you a search box where you can get all of the manuals for your tractor for free.
As to how to change your blade, I would suggest removing the deck and flipping it over. You should see the blade which wil be held on by a bolt. Block the blade from turning with a scrap of 2x4 lumber and you should be able to break the bolt loose. Reinstall it with a little bit of anti-seize lube and it should come off easily the next time...
TomTX
06-01-2005 15:46:04
Need some serious information in order to assist you. For starters what in the world is a "LT14H331KV tractor"??
