Tractor Talk Discussion Forum
Your help is needed to Identify please
Doug2
06-03-2005 08:15:50
I am trying to identify what make and model a backhoe loader is. It is an articulated machine with an LJ80335 engine that translates into a 4.236 Perkins. The other numbers on the machine are DGM1227/5300OM & LJ80335*U5224503W*L3072. One more series of characters on the machine is *60710056*. If any one can identify make and model of this machine please get back to me with your much needed help and assitance.
timm
06-03-2005 21:52:08
 Re: Your help is needed to Identify please in reply to Doug2, 06-03-2005 08:15:50
its a john deere
baby
Doug2
06-08-2005 20:25:46
 Re: HELP Your help is needed to Identify please in reply to timm, 06-03-2005 21:52:08
Was many years ago when John Deere took over Chamberlain that they stopped using Perkins engines. Also this has separate braking system and not inboard disc brakes like the JD units, that is this unit has normal DOT 3 brake fluid to operate a separate braking system. The rams and bucket do not look like the JD units. It also has a KOMATSU number painted on the machine after it was re-painted. Have has a suggestion that it could be a JCB, but then again the hydraulic system and rams for both backhoe and front bucket are not that of the JCB design. This articulated backhoe loader still remains unsolved, it weighs in at about 6 tons. Front and rear tyre are the same size and is 4 wheel drive.
