Tractor Talk Discussion Forum
Re: Marvel Carburetors
J. Schwiebert
06-05-2005 03:22:39
Mike: This is not about rebuilding one.
Alberta Mike
06-05-2005 06:34:42
 Re: Marvel Carburetors in reply to J. Schwiebert, 06-05-2005 03:22:39
I sort of thought that was maybe the case but I just mentioned it as a good reference. Good luck with your search. What sort of information were you looking for?
J.Schwiebert.
06-05-2005 08:05:54
 Re: Marvel Carburetors in reply to Alberta Mike, 06-05-2005 06:34:42
A couple of things. We are preparing a tech article for the HPOCA news letter and I ran into a situation this week on a TSX. The problem deals with how much fuel is there in the bowl when you pull it at rated horsepower and if you hit a certain overload condition.
Jerry/MT
06-05-2005 14:45:49
 Re: Marvel Carburetors in reply to J.Schwiebert., 06-05-2005 08:05:54
I'm intrigued by the problem you are trying to solve. Could you provide more details?
J. Schwiebert
06-05-2005 16:20:00
 Re: Marvel Carburetors in reply to Jerry/MT, 06-05-2005 14:45:49
To answer your post one question I have is how full should the bowl be when you place the tractor on a dyno. we made a tube to check the fuel level and we were surprised to see how much it dropped. Also if you read the other post If I write a tech article I need a reference source on some parts availability and other tech items.
Kelvin
06-05-2005 12:32:18
I don't have that info, but you can get an idea of what the fuel level is actually doing if you thread a nipple into the carburetor's drain and put a piece of clear plastic hose on it and fasten it so it curls up beside the carb. That is the way you check the float level is correct in some cast iron carbs.
