Tractor Talk Discussion Forum
Farmall H Stuck in Gear
Chris Cairns
06-06-2005 12:08:02
I have a Farmall H with the hand clutch add-on. I recently roaded it 20 miles and everything went well. I took it out a week later for a short run and it was still running just fine. It was parked for a week after the short run and when I went to take it out again it was stuck in gear. Whenever I let the clutch out and engage the hand clutch it acts as if it's in road gear even when it appears to be in neutral. Reverse and other gears do not seem to work which leads me to believe that it's stuck. Has anyone had this problem? What's the resolution?
tompepper
06-06-2005 18:47:04
 Re: Farmall H Stuck in Gear in reply to Chris Cairns, 06-06-2005 12:08:02
My H does that once in a while also.i just get hold of one of the wheels and rock it back and forth a few times and it seems to always jump out.then its ok for quite a while.GET-R-DONE
Chris Cairns
06-06-2005 13:24:06
Thanks for the info. What in particular needs to be replaced to prevent this in the future? Is there a kit or just specific worn parts?
RustyFarmall
06-06-2005 13:29:46
 Re: Farmall H Stuck in Gear in reply to Chris Cairns, 06-06-2005 13:24:06
The end of the shift lever is worn down. It can be built up again by welding. I can't remember the specific dimensions you want to achieve. You can search the archives or wait for someone else to jump in and give the answer.
Dave_Id
06-06-2005 12:52:54
Remove the shifter lever off by knocking out the pin. Take a hammer and brass punch and put the gears back into neutral.. You have the shifter in two positions. It happens often when these get alot of wear.
