Tractor Talk Discussion Forum
Putting hydraulics on ford 3000?
PLayman
06-06-2005 16:19:42
I was wondering how hard/expensive it would be to add hydraulics on a ford 3000 tractor
RWK in WI
06-06-2005 17:29:41
 Re: Putting hydraulics on ford 3000? in reply to PLayman, 06-06-2005 16:19:42
Depends on if you are talking about adding remotes ( $400 single / $ 700 double ) or adding a hydraulig system to a tractor that was built with out one. - Pump, manifolds, tubing, filters, controls, etc. Too expensive to do - you would be better changing tractors.
txgrn
06-07-2005 15:54:37
 Re: Putting hydraulics on ford 3000? in reply to RWK in WI, 06-06-2005 17:29:41
$75 for the adapter and about $300 at TSC will do the trick for a double acting single cylinder arragement.
check the archives> It"s all there.
Mark
RickB
06-06-2005 17:10:08
Pretty easy, once you write the check. $4-600 for a single or two spool valve, couplers & hoses. Other guys will post on how to do it cheaper with more hoses, fender mounted generic valves, and clutter.
