Tractor Talk Discussion Forum
cutting height adjustment for tractor
clem9
06-07-2005 16:01:41
I have a companion tractor, and have not been able to adjust the cutting height. I need to raise the entire deck up but can"t seem to find the way to do it. I"ve adusted the front to rear height, and the left to right leveling, this has not solved my problem. how do I adjust the height of the deck.
chris sweetland
06-08-2005 17:25:49
 Re: cutting height adjustment for tractor in reply to clem9, 06-07-2005 16:01:41
does your tractor have the lift lever on the right hand side? it should either have notches (fixed height deck) in that or it will be smooth (floating deck) and on the dash under the throttle there is a knob to adjust the height hope this helps sent the moddle # and maby i can help a little more
