Tractor Talk Discussion Forum
Woods Mower Problem
KRUSS
06-08-2005 14:38:03
I think the previous owner of my Woods Belly Mower may have put locktite on the bolts that hold the blades on. Tried to take them off with a swing bar and socket, no success. Tried swing bar socket snipe and friend built like a gorilla, no success. Tried an impact wrench and a bigger impact wrench (both ways too), no success. Anything more I fear will break the bolts off. I don't necessarily need the blades off right now, as I can always sharpen them on it. They will have to come off someday. Maybe I'll have to remove spindles and all when someday comes. Any ideas? Another question: This mower is run off the pto of a Farmall C. In my opinion the mower is not running fast enough. Wondered what size pulley others used??
RustyFarmall
06-09-2005 04:41:15
 Re: Woods Mower Problem in reply to KRUSS, 06-08-2005 14:38:03
Yep, left handed threads.
Doug Anderson
06-08-2005 19:12:08
My RM 306 is LH thread.
IanC
06-08-2005 18:25:24
Look at the way your blades rotate. The bolts are probably LEFT HAND thread. They are threaded to sort of be self tightening. Most Woods mowers use the LH thread bolts, as I recall the only units using "regular" threads were the units for Cubs, some older Kubotas etc. that had PTOs that turned "backwards".
aussietractor
06-08-2005 16:29:26
Kruss,Try heating the nut if possible, no more than dull red, do not allow heat to travel to blades, carrier, etc; have wet rags to disipate heat . It's amazing what a little heat can do. Good luck
