Tractor Talk Discussion Forum
another governor operation question
Leon R
06-10-2005 07:02:14
What is the most common problem that causes a governor to "hunt". Is it just a linkage adjustment or carb adjustment or a problem with the internals of the governor. I am experiencing that problem with my 1010 and am looking for advise before I get into it. thanks
Bob M
06-10-2005 07:57:17
 Re: another governor operation question in reply to Leon R, 06-10-2005 07:02:14
Leon - Governor "hunting" on a gas tractor can be from any of several causes:
1 - Carb high speed mixture screw set too lean. Try very slowly pulling the choke closed while the engine is hunting. If you find a point where hunting goes away, a lean fuel mix is the problem.
2 - Linkage binding. The linkage between the governor arm and the carb throttle must be as friction-free as possible. A sticky or binding linkage will tend to hunt.
3 - Worn governor parts. Sloppy flyweight bushings, a worn out thrust bearing, wear in the governor to carb linkage and loose carb throttle shaft bushings can all cause hunting.
4 - Improper governor spring installed. If the spring is too stiff, the governor will be too sensitive - hunting will result. (The opposite is a weak spring - this causes poor governor action and excessive RPM "droop" as the engine is loaded up.)
Good luck and hope something here helps!
Leon R
06-10-2005 10:12:16
 Re: another governor operation question in reply to Bob M, 06-10-2005 07:57:17
Thank you Bob, that is very helpful.
