Tractor Talk Discussion Forum
Case 220hydrive
Jon Pennock
06-10-2005 18:39:28
My 220 was recently serviced from top to bottom. It worked great. The last time I used it I parked it, shut it down, and all seemed normal. The next time I wanted to use it, it would not start. Nothing happened. I turned the key, nothing. The battery is charged, but nothing happens when the key is turned. No lights, and it will not initiate the starter. All help is appreciated.
john-mi
06-10-2005 19:02:57
 Re: Case 220hydrive in reply to Jon Pennock, 06-10-2005 18:39:28
If it is like my 446 you should check the fuse in the inline fuse holder. Everything goes dead when it blows the fuse. HTH. John P.S. the fuse holder is in a wire that goes into the key switch.
