Tractor Talk Discussion Forum
8N
Jerry Millard
06-12-2005 03:38:37
How can I tell what sherman trany I have, step up or step down, in my 8N? The tractor is in pieces right now.
Dell (WA)
06-12-2005 11:15:18
 Re: 8N in reply to Jerry Millard, 06-12-2005 03:38:37
Jerry..... ...both the 2-speed OverDrive Sherman and the 2-speed UnderDrive Sherman have a very simple "L" shaped shifter over yer left toe.
The more common and popular of the dealer installed 3-speed Combo Shermans have a dog-legged "S" shaped shifter lever.
I'm embarrassed to admit that I'd had my 8N with 3-speed Combo maybe 4yrs before I learned that it was a 3-speed and you PULLED the shifter handle out to the LEFT about 1" and then back toward you like OverDrive for DIRECT DRIVE..... ....Dell
Tim B in MA
06-13-2005 08:15:08
 Re: 8N in reply to Dell (WA), 06-12-2005 11:15:18
Only 4 years Dell - I owned my 841 about 10 or 11 years before I relized that there was a third range in the aux tranny - and then only because of reading the Ford forum here a good old YT.
old
06-12-2005 08:17:40
When apart the only way I know would be put it in each gear and turn the input shaft and count the turns you make on the input and the turns on the output. Say you turn the input shaft 1 turn and the output turns 1/2 turn that would mean you have a step down but if it turns 1-1/2 turns its a step up.
