Tractor Talk Discussion Forum
Air Intake
djhclovis
06-13-2005 12:59:03
I own a compact tractor that was modified by a prior owner. Specifically, the air intake boot (a rubber tube directing air into the air cleaner) has been replaced with a T-shaped device that appears to swirl the incoming air, and direct larger particles into a glass jar, before directing air down into the air filter.
I’m thinking of replacing this device with the original rubber boot, but before proceeding, would like to know, “Do these air-swirling devices actually work”?
Jon H
06-13-2005 15:30:54
 Re: Air Intake in reply to djhclovis, 06-13-2005 12:59:03
Yes the pre cleaners work, they seperate majority of the dirt,the large heavy particles out of the air stream before it gets to the main filter. On machines that run under very dirty conditions like a combine,I have seen the need to clean or replace the main filter go from once per day to once per season when a pre cleaner was installed. most modern pre cleaners have a venturi pump system built into the machines exhaust system so seperated dirt is sucked out of the pre cleaner and blown out the machines exhaust pipe. This eliminates the need to clean the jar or other container on the pre cleaner.
