Tractor Talk Discussion Forum
Case 990 hydraulics Help!
Hulsey
06-16-2005 16:21:22
I need help with the hydraulic 3 pt lift on my Case 990. It will go up with no weight on it, but won"t with an implement. If I pump the clutch it will go up about an inch. I changed the fluid, the filter, and cleaned the nylon screen to the right of the seat. Can anyone advise what it might be? Thanks!
geok
06-16-2005 20:24:29
 Re: Case 990 hydraulics Help! in reply to Hulsey, 06-16-2005 16:21:22
What weight hydraulic oil did you put in? Sounds like your hydraulic pump may have blown an O ring where the pump bolts to the housing.
Hulsey
06-18-2005 15:28:41
 Re: Case 990 hydraulics Help! in reply to geok, 06-16-2005 20:24:29
regular tran oil. What the tractor guy recommended. I might need to bleed the system, but cannot find the bolt to do so....can you help
