Tractor Talk Discussion Forum
Ford 3000 sos transmission fluid
jp, TN
06-17-2005 10:04:51
I just got a Ford 3000 with select-o-speed transmission. The operators manual says to put Ford M-2C41-A in the sos transmission and power steering. The hydraulic system calls for M-2C53-A (which would also be used in the transmission of a manual transmission) I have read some on this site that New Holland 134 could be used for all of these applications. I wanted to make sure that it was ok to use specifically in the sos transmission because I have also read on-this site where using the wrong fluid in the SOS has caused some significant problems, or if there is a better fluid alternative.
