Tractor Talk Discussion Forum
986 W/Hay Roller
RWalker
06-21-2005 08:59:31
Just bought a 986 to pull my IH 2400 hay roller. Should the roller stop the power take off on the tractor when the roll gets around 4 ft or the feed roller gets clogged up. Need help figuring this one out. I was pulling it with a 584 and didn't have this problem.
Walter Squires
06-21-2005 10:02:30
 Re: 986 W/Hay Roller in reply to RWalker, 06-21-2005 08:59:31
Better set the pressure on the PTO unit before it's too late, I belive it is 135 to 145 PSI on a 986.
Allan in NE
06-21-2005 09:03:40
R,
Sounds like your PTO clutch is slipping if it is stopping at the tractor.
Allan
RWalker
06-21-2005 09:45:42
 Re: 986 W/Hay Roller in reply to Allan in NE, 06-21-2005 09:03:40
Allen
Not much of a mechanic .What does that mean to get it to work is there and adjustment somewhere.
Red Dave
06-21-2005 11:19:32
 Re: 986 W/Hay Roller in reply to RWalker, 06-21-2005 09:45:42
I can't answer your question, but if you go over to the IH/Farmall Board of this fine site, I'd bet somebody there can help you out.
Here's a link:
