Tractor Talk Discussion Forum
JD 3020
za766
06-22-2005 05:00:08
I have a JD 3020 that has the left rear wheel and the power steering to lock up intermittently while you are using it. Based upon this I am pretty sure it is in the hydraulics and the fluid level is fine. Is there a good starting place to troubleshoot without having to start with the pump? Any suggestions would be appreciated. Thanks in advance for any of your help.
msb
06-22-2005 19:14:28
 Re: JD 3020 in reply to za766, 06-22-2005 05:00:08
If that is the case then I would hva the steering valve and the brake valve rebuilt.Are you sure the brake pedal is releasing all the way? I have seen the pedal pivot pin or the piston cup get rusty and keep the pedals from releasing.
za766
06-22-2005 10:30:03
The only oil run in the transmission in the last 20 years that I have had it is the John Deere HyGard. It has been a little over 2 years since I changed it and the filter. It may get approximately a 100-150 hours on it a year and nothing really hard working, mainly haying.
buickanddeere
06-22-2005 09:41:50
What kind and brand of oil has been dumped into that transmission?
msb
06-22-2005 08:49:31
Just a guess ,but I would suspect the brakes have disintegrated and the trash has gotten into the steering and brake valves.Start by removing the transmission filter and give it a very good inspection by cutting it open and looking at the pleats of the filter.Hope I am wrong.
