Tractor Talk Discussion Forum
3020 powershift problems
Dennis Webber
06-24-2005 10:58:30
Need help with powershift on 3020 diesel. First problem is tractor takes a long time to start moving after putting it into gear. When you engage the pto, the tractor stops. Disengage power take off, tractor will move after a length of time. I have checked the filters and the filter screen. Filter screen was very clogged, but after cleaning, still have the same problems. I am getting ready to split the tractor and look at the transmission pump. Any other ideas or solutions let me know. deererunner
Ducknose Bob
06-25-2005 04:11:23
 Re: 3020 powershift problems in reply to Dennis Webber, 06-24-2005 10:58:30
It doesn't take much scoring in the front pump to lose a lot of pressure. Replace the torsional dampner while you have it split.
msb
06-24-2005 19:31:14
Clogged with what, Dennis? Does it look like it could be brake pad material?I would put master gauge on the transmission first and then pull the valves off both sides of the transmission and check them for trash before splitting the tractor.If your brake pads have disentegrated that is where you will find it.The transmission pump is probably o.k..
Tx Jim
06-24-2005 11:22:24
Dennis,I would check trans.pump psi and tranny psi's before splitting.Visual observation of a component is not easy.It's possible it could just be a faulty valve.Tx Jim
