Tractor Talk Discussion Forum
Need to identify these fuel injectors
Mark in AB
06-28-2005 08:42:32
Acquired 6 of these injectors with return lines painted red, injectors appear to have just been rebuilt. I am not sure how to post a pic here, but if you can help I will email you some. Not like any IH injectors I have ever seen.
CAV - made in England
BKB17755010
DN5221501
Thanks in advance
Rod F.
06-28-2005 19:35:06
 Re: Need to identify these fuel injectors in reply to Mark in AB, 06-28-2005 08:42:32
Ford, Massey, and David Brown / Case all used CAV fuel systems on many different tractors. The Perkins in the Masseys should all have gray paint. Ford, blue. It's possible that some of the Brown's had orange paint. However, I was just thinking now that mabey the lines didn't necessairly come with the injectors. Paint might not mean a thing.
You might try taking those CAV numbers and call an injection supply. They could probably tell you what engine they fit, or at least what their spray characteristics and delivery rate is supposed to be. I doubt that the CAV numbers would mean much to most tractor dealers. HTH.
Rod
Mark in AB
06-28-2005 20:38:36
 Re: Need to identify these fuel injectors in reply to Rod F., 06-28-2005 19:35:06
thanks I will give an injection shop a call.
Kevin (FL)
06-28-2005 12:10:40
Mark,
I have posted detailed step-by-step instructions on how to post photos on this site. Several other folks have done the same as well. Check the archives for posting a photo so you can show your pictures of the injectors. My first guess without seeing them (from "Made in England") is Perkins.
