Tractor Talk Discussion Forum
OT,Leech Beds???????
SJ
07-04-2005 06:30:29
Well Ive got a backhoe now and at the end of my leech field sewage is rollin out of the ground like oil on the Beverly Hillbillys.I dont know anything about installing one,is this something I could get info on and do my self.At this time my tank(round metal)is still in pretty good shape.Could I go with a new leech system now and go with new tank down the road?Also I dont even know if I have a distribution box.I would guess not.Would one of those be required now with just new leech beds or when I need a new tank? Any idea on cost of this with me doing the labor?
Im gonna search the web to see if I can get some kind of info or plan.Are there any sites anyone knows about to help me with this?
Thanks
Stan
Eddie Bolch
07-06-2005 11:03:06
 Re: OT,Leech Beds??????? in reply to SJ, 07-04-2005 06:30:29
Her goes my $2 worth. 11 years as inspector 10 years as designer. Drain fields usually only last 15-18 years ast best because biological mat (slime) fills holes from pipe due to constant moisture and bacterial growth. Systems function depends a great deal on type of soil. If real sandy, effluent goes down through soil and percolates and gets cleaned and you never see it. If you have heavy clay, the only way to get rid of it is to evaporate it. This could require drain fields for 3 bedroom house (240 gpd) to go from 600 sq ft for sand to 3200 sq ft for heavy clay (Central Texas Area). It doesn't matter how you get the square footage, rock and gravel, infiltrators (incidentally, don't get a sq ft reduction in clay soil), graveless pipe, or whatever. Also drainfields must be mowed just like your yard, if grass gets tall, it insulates the soil and prevents sunlight and evaporation. A technique learned lately is to divide total drain field into two equal units with valve. Use 1/2 of drainfield until it gets saturated then swith valve and allow field to dry (reduce slime volume). Then switch fields again when other one fills. The reasoning behind keeping drain field lines in top 24-36 inches of soil is more sidewall penetration and evaporation potential from sun and wind and grass moisture uptake.
In this area the aerobic spray dispersal units go in cheaper than an inground system in clay soil. If you have sandy soil, cost flips.
Systems installed in early 70's had several design flaws that were corrected over years of trial and error, also personal water usage has increased thus drainfield size requirement has increased. Now, media between rock and sand cover is geotextile fabric this keeps the sand from filtering down and filling the holes between the rocks but allows the moisture to wick up to the surface (this is void space to hold effluent from the pipes until it can be disposed of through soil or sunlight). Esperience has shown that tank capacity should be divided to two tanks or compartments. Never metal, but concrete or fiberglass. Tanks should have turn downs to help separate soilds, grease, hair etc from liquid so the soilds don't flow down into drainfield and clog up holes which reduces the total amount of drainfield available which makes the effluent surface.
The drain field lines should be within 24 inches of the surface to make it easier for the effluent to evaporate or the vegetation roots to tap the moisture and draw it up into the plants.
Now, most enteties have some kind of inspection program to ensure that systems are put in properly. Talk to them, most will help in any way they can because it is easier to make changes with a pencil and paper to correct an error than it is to redig and relay pipe and gravel. The biggest mistake tha most first timers make is to try and install drainfield lines going down the slope. If they do, all the effluent goes to the bottom of the slope and surfaces. Think of the drain field lines as a soaker hose and run it in a level contour of the land so that the effluent soaks inthrough the total length of the line.
This is long but I hope it helps.
Eddie Bolch
07-06-2005 07:48:05
Joe MD
07-05-2005 14:07:03
Just curious, but what do septic systems cost anyway?
Our system was installed in about 76 and I don't believe it has a leach field. Never been pumped out to my knowledge.
Don't seem to have a problem, but we may be doing some renovations and I'm sure we'll find out something is seriously wrong . . . money pit.
Ballpark?
paul
07-04-2005 22:35:45
Very few places allow you to this legally any more. At the least you will need inspection as you go, likely you need to hire a licenced company to do this.
If not, or you wish to ignore such issues, figure out why you are having problems. Has the tank been pumped of late, has it rained a lot, a change in the # of people living there - what? If you have a septic problem, you need to figure out the real cause so you can really fix it.
Most codes require something way different than what the folks here are suggesting, so proceed with an open eye....
--->Paul
buckva
07-04-2005 10:54:42
Before yo start diggin and adding lines lets address a few things. First the flow from the ends of your drain lines is probably the least problem you can have with one of these systems. Proble cause is that more water is gettin to that point than any other pont in the system. It is moving too freely thru the rest of the system and all ending up here. If you only have one line then the problem is easy to address. Probably add more line on a flatter grade or a pit to hold the flow. Now if you have multiple lines the the problem is probably in the timein/distribution box. Now these things work well at the flow they are designed for but when a lot of water enters the system then the water takes the path of least resistance and all ends up in one line and then you get flow to the surface of that line. I would suggest that you locate your distribution box, open it up and see what is going on. If you only have one line and you already know that the flow is reaching the end good then I would add to the field.
Billy NY
07-04-2005 10:05:47
Do a search for septic system design, and or any like variant, you'll find plenty of information on systems I'm sure. I recall looking early this spring, as I had a clog right before the tank and was trying to figure out what was up.
I've spent many years in the earthwork field as an operator and early on in that line of work, I was employed by a small to medium site contractor who used to do new septic systems as well as other site work. Aside from setting the tank, it did not take long before I was doing 2 systems per day, by myself, used to load up the tandem dump with #2 stone, hook the tag trailer with the hoe on and off I go. Depending on the site location, the additional stone I needed was usually nearby, make a few runs to the quarry afte unhooking, we used to stock all the small components like pipe, and distribution boxes etc., so I'd load that on too. All I needed was the plan for the system and to have the hole ready for the pre-cast outfit to set the tank and the rest was seemingly easy. Not bragging, but those days were a little long, but recall many where I did 2 per day, which made the company decent money, and of course I was treated well for my hard work.
You can tie in a new leach field from the distribution box, might even add a new D-Box, you can set each lateral to take an even amount of discharge by setting the plastic leveling devices that come with the box. I'd pump out the steel tank though, but for the cost of a concrete one, I'd prefer to just replace that too, if it was in poor condtion or the size was not to my liking, that is me though, does not mean it is necessary, I'm a little big on overkill sometimes LOL !
Aside from any munincipal or health dept. requirements that mandate minimum size of the system, over building here is never a waste of money and pipe, stone etc. it is cheap when you consider the increase in service life and the future expansion it will allow you.
My preference is to double the size requirement, from the tank capacity to the leach field size,if posssible, my present residence is double capacity and has given almost 30 years of service with no trouble.
The problem a leach field faces is when the tank is not pumped when needed, the fine particles get into the stone bed and clog it up, which renders the field useless, it can be rested and re-used, or replaced, but in any event you still have a problem. Read up on how a septic system functions, bacteria plays a key role in this, at this place, only toilet discharge goes to the tank, all other discharge goes to a drywell, effectively eliminating soap water and household chemicals from the system so it does not kill the bacteria. At this place, the tank had never been pumped until 2002, it was set in 1978, but it was much larger than required, we had a weird series of events late that winter '01-'02 and the ground became saturated and the frost line would not allow any percolation, so it backed up, pumped it and it was fine, now I do it every 3 years, I found a chart on this on the internet not to long ago.
Your basic lateral profile is about 12" of clean crushed #2 stone bedding, + or - , it's been awhile, then run your perforated pipe, holes to the side, on 1/8" / foot pitch min., you can use an optical level to set your grade or use an accurate 4'-0" hand level on top of each length of pipe to insure pitch, then bury in crushed #2 stone, we placed red rosin paper over that then backfilled with 2'-0" of good material, no large stones etc. You want to excavate your lateral trench on pitch, allow for a healthy bed of stone at least 1'-0", then your 4" pipe, stone cover, and top off with what you excavated or something suitable that won't crush the pipe. I used to backfill with a dozer and go across each lateral, not parallel, a dozer has much less ground pressure than a rubber tire hoe like you have so you may want to use the hoe from a vantage point that will keep you from driving over the new laterals with a full bucket, that is why it's good to plan out your moves from digging to backfilling. When I had a dozer I could leave the entire field open for the inspector to see, then work my way across to backfill, other times where there was not inspection and a dozer was not present, I'd do one line at a time and back fill it with the hoe, that is if I couild reuse the material I took out. Really not a hard task, do your research, get an approved plan and or design if need be, plan out your job, check your material list, call the 800 number "before you dig" and have a go at it, I've done a few systems with buddies on a saturday, enjoyed a cold one afterwards, usually more fun than work !
PS, I always thought the red rosin paper on top of the stone covering the pipe was a joke as it would seemingly rot away soon after, but I guess its to keep the cover material from choking the stone up while backfilling only, and I assume if you used something like plastic, it would stop evaporation from happening or similar by making a barrier and screwing up the works somehow, I never figured that one out, but was and probably still is, the accepted practice to use this paper over the stone covered pipe before covering.
Best of luck !
720Deere
07-04-2005 09:49:51
I know I will catch some flack for this, but here's my advice. Conventional septic systems are designed to systematically fail. What happens is the perferations or holes in the pipe begin to grow shut and clog with time. This starts up close to the distribution box and carries on until the entire pipe is clogged. That is usually what has happened when you get the wet spot at the end of the field.
If your drain field doesn't have much cover over the top of the stone, I would try to dig it up in a few places to see if the pipe is plugged. Many times, you can just replace the pipe and the top 8" to 10" of stone and you will be good as new.
The infiltrator systems work pretty well in the right soil conditions. I am skeptical about them vs. stone & pipe because they are more designed for storage than seepage and they don't give you near as much ground contact as the stone pit does. With the stone design, you have ground contact with the sides and the bottom. The infiltrator will give you good bottom contact and about 3' height of side contact, but the stone pit is usually much deeper giving more ground for the liquid to seep into.
If you end up putting in a new drain field, make provisions to tie the old one in to the distribution box. After a year or so, that old field will be ready for another go and will make a good backup. A friend of mine has a house on 1/2 acre and the drain fields are too small. His distribution box favors the shorter of the two fields so it started to fail. We opened the D-box and created a brick weir to limit flow to the short field and everthing works fine now.
The health department doesn't like it, but that old field would make a nice drain field for the washing machine. Most times drain field pipe failures can be attributed to lint from the washing machine so it's nice to keep that seperate if you can.
Bus Driver
07-04-2005 15:57:38
 Re: OT,Leech Beds??????? in reply to 720Deere, 07-04-2005 09:49:51
I do disagree with parts of the post by 720Deere. My son is a PE and works for Hancor which makes the "Envirochamber", a directly competitive product to the Infiltrator. The stone REDUCES the soil area available for effluent absorption. Rocks do not absorb much liquid. A search on Google for the products mentioned above will produce lots of information. If searching, the correct spelling is "leach".
720 Deere
07-04-2005 17:32:09
 Huh? in reply to Bus Driver, 07-04-2005 15:57:38
I'm not looking for an argument, but how could a trench that is only 3 feet deep provide more ground contact than a trench 10 feet deep?
By the way, I've used all the Infiltrator type products over the last ten years and they have had their share of problems. I saw a new car dealership parking lot cave in with about 20 cars going into the hole. The units were installed per the manufacturer's design and still failed miserably. One thing you learn in the business is that people will say just about anything to sell their product. Hancor is good people, but they will be sorry that they ever got into the "doghouse" business.
Tx Jim
07-05-2005 04:42:26
 infiltrator system in reply to 720 Deere, 07-04-2005 17:32:09
720 Deere,I've had an infiltrator septic system for 4 yrs and see nothing wrong with it other than one shouldn't drive vehicle over it.It contains no rock and in summer the grass doesn't get greener than surrounding grass like most conventional septic systems. County officials here PUSH those stinking,expensive arobic sprinkler systems but I fought them to get a conventional. Tx Jim
Tx Jim
07-05-2005 04:41:55
VaTom
07-05-2005 03:45:06
 Re: Huh? in reply to 720 Deere, 07-04-2005 17:32:09
10 feet deep? Wow.
Here in central Virginia the trenches are the same depth, stone and Infiltrator. Difference is the required lines. Infiltrator reduces the leach field size by 1/3. Our health department clearly believes stone systems to be inferior for leaching.
The guy I routinely recommend uses almost nothing but Infiltrator now. His price per system went down significantly. They"re working fine. The one I had installed for a client house has had light vehicle traffic, no damage.
paul
07-04-2005 22:27:26
I'm just currious who is making 10 foot deep trenches, why, & who is approving such a thing? Never ever heard of such a thing. My state' county wants the stuff leaching out into the top foot of ground, not 10 feet deep.
--->Paul
ChadS
07-04-2005 08:44:15
Usually, when you have to get the permit to repair, or replace the septic system, they county usually makes you replace the tank as well, depending on the age of your old system. They will have to make your system up to code, which will require a Distribution box, and a minimum of 300 ft of leach field. Depending on sqft of your home. there is a newer system out there that you dont have to use the old rock and perferated pvc pipe, its called "Infiltrator" You have to dig the same distance and trench to the same spec, but all it is is like 1/2 a 55 gallon plastic barel cut in half that snap together end to end. It still costs about the same as the rock method, but you save a lot of time on installation, bout 1/2 the time actually. Check with you health department for the code updates, have soil samples raken, and go by the book, cause, when they come inspect it, you eithr pass, and you get to cover it up,, or you have to correct it before you are allowed to cover it back up. Just depends on how your health codes in your county are written. Have a look at that new style leach field,, Ive had one for years n years, with out any back ups, and its in pretty hard soil. if its a wet land area, go with the rock and perferated pvc, but if not, new style works great! Hope this helps,,, I worked in excavation for a few years and put systems in the darnedest places. good luck, ChadS
Can't even use my name
07-04-2005 10:11:18
 Re: OT,Leech Beds??????? in reply to ChadS, 07-04-2005 08:44:15
Around here they determine your septic system size according to number of bedrooms and whether or not you have a jucuzzi tub. Only real down fall to the infiltrator system is you can't drive anything over where it is or it will cave in, the pvc can handle a good load, of course you wanna try to avoid driving over it anyways but if someone forgets and goes across your field I'd rather not have to dig it up to repair it. Other than that they seem to work great.
ricks41-9n
07-04-2005 07:47:23
Try this link it has a lot of good information. Rick
www.eco-nomic.com/septic.htm
Tim Casbolt
07-04-2005 07:38:28
Finding information about fixing this is a very good first step. And it is something the average handyman with a backhoe can handle. But before you do any digging, call the 800 number and make sure there are no underground utilities that you could hack into. It's a law.
