Tractor Talk Discussion Forum
paper gasgets
alex7407
07-06-2005 07:24:59
Has anyone ever heard of using a brown paper bag for replacing paper gasgets. Someone mentioned it once and I just wondered if it would work
Alberta Mike
07-06-2005 16:59:11
 Re: paper gasgets in reply to alex7407, 07-06-2005 07:24:59
Never used brown paper bags but have often used boxboard (cornflakes boxes, poster paper, etc) for gaskets and it works fine. Sometimes I use it as is, other times I coat the surfaces with Permatex gasket cement. I HATE silicone, absolutely hate the stuff.
JaKE
07-06-2005 12:08:08
I tried the cereal box gasket some years ago. What a joke! The oil soaked right through the stuff. Use genuine gasket material instead.
David in MD
07-06-2005 10:41:36
I had a seasoned mechanic help me on a Detroit in a truck and needed a water pump gasket which wasn't in the kit. He took a manilla file folder held it over the part and took a small ball pien hammer and tapped out the outline of the gasket. The gasket punched out almost factory like. The gasket held.
billyiron
07-06-2005 07:28:59
yep it will work,,as long as you aint got a real serious situation,high pressure etc,,smear both sides with shelac,,it'll go,,,,billy
RustyFarmall
07-06-2005 07:47:36
 Re: paper gasgets in reply to billyiron, 07-06-2005 07:28:59
Brown paper bag, the cover of a Sears catalog, even the cardboard back from a legal pad or such. All will work in a pinch, sometimes better than an exact replacement.
jake3x
07-06-2005 08:04:46
 Re: paper gasgets in reply to RustyFarmall, 07-06-2005 07:47:36
NAPA sells gasket material by the foot why use something that's going to fail and have to redo it again.
Jimmy King
07-06-2005 09:43:02
 Re: paper gasgets in reply to jake3x, 07-06-2005 08:04:46
Have used lots of paper and single ply cardboard over the years, and haven't had one fail yet.
Dick L
07-06-2005 11:10:39
 Re: paper gasgets in reply to Jimmy King, 07-06-2005 09:43:02
Started using brown paper bags, cornflake boxes, and such to make gaskets in a pinch back in the 1950"s. I don"t recall any that failed. Just need to check the thickness of the gasket being replaced. You can not replace a 1/16" or 1/8" thick gasket with a .007" paper bag.
riverbend
07-06-2005 19:55:49
 Re: paper gasgets in reply to Dick L, 07-06-2005 11:10:39
Right, the thinner the gasket, the flatter the surfaces have to be.
