Tractor Talk Discussion Forum
International 4366 questions
jkloepping
07-06-2005 18:48:17
I"m looking at an old 4366 for sale, but brakes don"t work. The owner doesn"t know much about it, and all he could show me was a single large disc in the center of the machine that someone removed the calipers from. I"ve seen emergency brakes like that before, but never brakes for a whole machine. Are there also band brakes somewhere? Are used parts hard to find? The steering is also weak, and even at $2500 for the whole thing, I"m wondering if it is such a "bargain". The motor runs strong and smoke free.
thanks
Jon Hagen
07-06-2005 21:30:01
 Re: International 4366 questions in reply to jkloepping, 07-06-2005 18:48:17
The 4366 is Really a Steiger tractor built in the Steiger plant in Fargo ND with a mix of IH and Steiger parts. The single large disc brake on the front axle driveshaft is the only brake used or needed. The little 466 IH engine was seriously overworked in that size tractor.The axles,which were modified IH 2 wd tractor axles also had problems in that application. Still not a bad old tractor if you do not overload it.
bigdiesel
07-06-2005 18:53:24
the engine alone is worth the 2,500. it uses the 1066 rears and axles. put on calipers and use it. i have a new rotor for one if you need that too.
