Tractor Talk Discussion Forum
Gas leaking into oil
MarkinMo
07-09-2005 05:59:00
I have a Scag zero turn mower with a 19HP Kawasaki V twin engine. I checked the engine oil level a couple of days ago and noticed it was quite a bit above the full line. I decided to change the oil and what drained into the pan was very thin. Only thing I can figure is that gasoline is leaking into the oil system. Has anyone ever seen this?
Cosmo
07-09-2005 15:25:25
 Re: Gas leaking into oil in reply to MarkinMo, 07-09-2005 05:59:00
Not familiar with this configuration but if your gas tank is higher than the carb it may also be a sticking float or leaking needle valve. I've had this happen more than once. HTH. Regards, Cosmo
Weirsdale George
07-09-2005 13:29:17
Does your engine have a mechanical fuel pump -- it could have a ruptured diaphram leaking gas into the oil.
MarkinMo
07-09-2005 15:09:28
 Re: Gas leaking into oil in reply to Weirsdale George, 07-09-2005 13:29:17
I think maybe it does. I'll have to look into that. Thanks for the tip.
yoda
07-09-2005 06:14:39
yep i have it ended up being that the rings were shot
