Tractor Talk Discussion Forum
K341 16 HP Kohler Motor
Frankie
07-13-2005 10:32:52
Hi. Just hooked everything up on the K341 16 HP Kohler motor. It would just catch and would keep trying to start but not actually starting. Tried carb adjustment: No difference, theres gas into the carb, and points have spark. My uncle is a mechanic and he said that a valve may be stuck. Is there anything else that could be wrong??? Please Help!
Weirsdale George
07-13-2005 18:10:38
 Re: K341 16 HP Kohler Motor in reply to Frankie, 07-13-2005 10:32:52
a) Did the engine run before you "hooked everything up"?
b) Squirt some starting fluid into the carb -- if it doesn't try to run, you have an ignition problem.
c) If the plug is a Champion, replace it with Autolite, even if new.
Frankie
07-13-2005 20:18:05
 Re: K341 16 HP Kohler Motor in reply to Weirsdale George, 07-13-2005 18:10:38
I dont know, I didn't get it w/ everything hooked up.
I did w/ no result and yes I already know I have an ignition prob.
it is a champion but does autolite make a H10C?
Weirsdale George
07-14-2005 07:54:42
 Re: K341 16 HP Kohler Motor in reply to Frankie, 07-13-2005 20:18:05
If you can't find an Autolite equivalent, use any other plug but Champion. I (and a bunch of my friends who collect small antique engines) have had nothing but problems with champion plugs -- we figure the relatively low compression engines and the "new" gas is a cause of the proble.
Another thing you might want to check is if the flywheel key has been sheared.
Frankie
07-14-2005 16:29:14
 Re: K341 16 HP Kohler Motor in reply to Weirsdale George, 07-14-2005 07:54:42
I'll take note of problems w/ Champion sparkplugs. There is no flywheel key that has been sheared.
frankiee
07-13-2005 13:09:44
Is the gas getting out of the carb?
Try squirting some in to the carb bore.
Points are a pain and hi maintainance
Set the points to spec and make sure clean with a white paper.
Does it have compression?
Roll over by hand and try to get a "feel" for it if you dont have a compression gauge.
"Feel" the compression of a known good one and compare the two.
I usually start with a new plug (also high maintainance part). Even if the old one looks good.
Good user name.
Frankie
07-13-2005 14:08:35
 Re: K341 16 HP Kohler Motor in reply to frankiee, 07-13-2005 13:09:44
Yes there is gas getting out of the carb.
The points are clean but I will replace them with new points, just to be sure.
Yes has compression.
I have a new plug. Never used before I tried starting it.
I am having my uncle look at for he is a personal mechanic.
