Tractor Talk Discussion Forum
I needed Transmissions for Dummies...
JW in Oh
07-14-2005 12:15:24
third party image
Yesterday the transmission in my MF to35 got stuck in reverse. The gear shift wouldn't budge. I remember reading here that this is a common problem, but couldn't remember the solution. With a bad cell phone connection, I spoke with my mechanic, but got nowhere. After about an hour I fixed it mostly by accident. The procedure is perfectly described in Big Deans site: Link but I thought a picture might help. This is a pic taken thru the fill hole on the top of the transmission. In essence, you need to pry the large gear on the left(toward front of tractor) either forward or back to get it in the middle of its range. This will get it all back in line and the shifter will work again. I hope this helps save someone an hour or two. Also, why is the inside of my tranny casing red? Is this normal?
Matt from CT
07-14-2005 16:43:03
 Re: I needed Transmissions for Dummies... in reply to JW in Oh, 07-14-2005 12:15:24
My TO-35 does that in 2nd gear. Never got it stuck in reverse...
Remember the first time it happened posting here in terror I had just ruined my transmission :)
Matt Smith
07-14-2005 15:49:25
Somebody has obviously installed your transmission housing inside out!!!
Galen
07-14-2005 14:19:05
Aren't all tractors SUPPOSED to be red? 8^)
GregCo
07-14-2005 12:37:27
The inside of the case is painted to prevent rust from mixing with the oil. The rust comes from condensation inside the gear case. After a while you get rusty oil. The rust wears out bearings and gear faces.
Jon Hagen
07-14-2005 18:29:30
 Re: I needed Transmissions for Dummies... in reply to GregCo, 07-14-2005 12:37:27
Also the paint inside the transmission case will trap any left over casting sand imbedded in the surface of the cast iron. This way it never gets loose to wear gears and bearings.
Mike M
07-14-2005 12:48:23
That paint also seals up the pores of the castings to help keep them for seaping out fluid.
Mike (WA)
07-14-2005 13:33:55
 Re: I needed Transmissions for Dummies... in reply to Mike M, 07-14-2005 12:48:23
The red also supplies much better contrast, resulting in superior digital pictures.
Joe MD
07-14-2005 13:49:10
 Re: I needed Transmissions for Dummies... in reply to Mike (WA), 07-14-2005 13:33:55
ha ha ha ha ha
