Tractor Talk Discussion Forum
WD45 bushhog
Lary1r
07-14-2005 18:50:09
What size bushhog should I try to find for a wd45 to mow a small pasture and maybe a little work along the edge of fields?
Sid
07-14-2005 21:37:29
 Re: WD45 bushhog in reply to Lary1r, 07-14-2005 18:50:09
Used to do a lot of mowing for an older fella who is gone. He had a seven foot pull type on a WD 45. Cut a lot of weeds and light brush.
Bill(Wis)
07-14-2005 19:57:51
I have a Land Pride RC2572 (6') that weighs in at around 1100#. That's a load and a half for a WD. The front end does want to come off the ground when lifting it so be careful. Otherwise, you will have enough power to run it just fine. I trust that you have a 3 point lift on your tractor?
old
07-14-2005 19:09:44
6 footer is just right for it
