Tractor Talk Discussion Forum
HELP - 48 AC WD TUNE UP INFO NEEDED
CLAY RANDALL
07-15-2005 08:08:31
1ST TIME MECHANIC, I'M TRYING TO TUNE UP MY WD, HAVE PROBLEMS TRYING TO LINE UP MAG COVER GEARS FOR PROPER TIMEING, PLEASE, I NEED ADVICE OR A PLACE TO GET TUNE MANUAL & DIRECTIONS THANKS IN ADVANCE!
Glen in TX
07-15-2005 13:08:15
 Re: HELP - 48 AC WD TUNE UP INFO NEEDED in reply to CLAY RANDALL, 07-15-2005 08:08:31
Some tune up specs in left hand columns here and they have some manuals on here too. Do a search on the AC forum for lots of info too or just ask there. If you have the FM-X mag there should be a mark on the magnet shaft gear that aligns with the "C" mark on the fibre rotor gear. Then get your engine on TDC on #1 front cylinder and line up the rotor with the tab in the cap at about 11 o'clock to time the mag to engine. Set points on the X mag to .015". On the FM-J mag align the mag gears the same way... C to the gear mark for Clockwise drive mags and A to the mark for Anti-Clockwise mags and set points at .020". There was some good AC info at this also: Link If you need more help let me know.
