Tractor Talk Discussion Forum
bondo, can it fix her
old fashioned f
07-16-2005 07:23:27
Howdy folks,
Been a while since I've been in. Talkin to a fella at the store the other day, he mentioned using bondo to seal up those plates I made for the water leak on my JD R. Dad said "Naw, it won't work". The guy though, is one who I trust. He owned an R and has worked on a heck of a lot more tractors than me and dad put together so I am knockin that idea around. What d'ya think? Would it hold? Dad thought the heating up and cooling down of the block would get it broke loose. As I recall, that block doesn't get hot at all when it isn't running out of water so I have my doubts about it coming loose. I have plenty of bondo "in stock" at home lol. Other than that all I can do is have my neighbor look it over and see if he can braze or weld the patches I made so they'll be permanently on there. Have a good 'un. God bless.
--old fashioned farmer
p.s. Never did send in anything to the weather job in S.D. :)
Mike M
07-16-2005 17:24:29
 Re: bondo, can it fix her in reply to old fashioned farmer, 07-16-2005 07:23:27
I still say while you got it apart get a good used block and fix it right and then you will have something that will hold up without worry.Anything else is just a patch that the next guy is going to get stuck with having to fix.
Bus Driver
07-16-2005 15:50:40
Ordinary Bondo is polyester based. JB Weld is epoxy, as is the Devcon product. Epoxy has about 5 times the bond strength of polyester. Bondo does make an epoxy based filler, but it is very hard to find. About 8 times as expensive as the polyester based.
Vern_MI
07-16-2005 11:24:49
I have seen wet sleeves in a diesel sealed to the block using Bondo. The sleeves normally use O-rings to seal but the surface was to badly eroded for the O-rings to seal so Bondo was used. It worked great and didn't leak a drop.
farmweld
07-16-2005 11:17:29
i agree with wiersdale george, use JB Weld, and get her real real clean. by the way, which Equipment superstore are you at? i was in the wilmington store friday, last weak
hope you get the girl runnin,
farmweld
Davis in SC
07-16-2005 08:56:26
I have repaired some cracked dies so they would not leak, using Devcon epoxy. Then. I would pour some Low-Viscosity Loctite in the water channels, & apply air pressure. The air forces the Loctite into any small cracks, where it hardens. Some of the repairs have lasted for years, running water from 150 to 210 degrees. I think the Loctite grade is 290, also refered to as Wick & Lock.
Weirsdale George
07-16-2005 07:36:44
If I were sealing a water leak in a block, I would use JB Weld. Make sure the surfaces is very, very clean and dry -- I can't stress that enought.
UncleTom
07-16-2005 13:08:07
 Re: bondo, can it fix her in reply to Weirsdale George, 07-16-2005 07:36:44
I once jb welded a spark plug in a honda trail 70 because the kids stripped the threads. I didnt have time to change the head at that moment so i cleaned it up real good and used a cleaner and jb'd it in and around it thinking that the kids could ride for a day or so anyway.I had a head sitting on the bench. But i wanted to see how long it would last first. I figured the hot cold cycles would break the weld. It never did come out and i never did change the head. Just my .02
Jerry Cent. Mi.
07-16-2005 15:12:26
 Re: bondo, can it fix her in reply to UncleTom, 07-16-2005 13:08:07
I use both bondo (Body Repair) and JB Weld but I like PC-7 better.
