Tractor Talk Discussion Forum
checking accuracy of tach
mikeinWA
07-16-2005 08:10:38
Any easy way to check accuracy of tractor tachometer on a diesel rig. I am beginning to suspect mine is off and reading high. At least thats what my ear tells me. On this particular rig rated is at 2250, and max at 2450. There is plenty of throttle to bury the needle past 2500.
Thanks
RAB
07-16-2005 13:18:23
 Re: checking accuracy of tach in reply to mikeinWA, 07-16-2005 08:10:38
Attach a relatively slow moving item on the pto and count the revolutions per minute and compare to theoretical. Eg count the number of ram strokes on a baler.
Attach a generator and check the frequency of the output with a DMM.
Put a strong flourescent light on a moving part and check rev counter for when it appears to stand still due to the stroboscopic effect. Calculate back from your mains frequecy to the speed of the item.
You could, of course, beg, borrow or buy an electronic tachometer and check it..... ...
Or get your ear calibration checked out and certificated!
Hope this helps. Regards, RAB
