Tractor Talk Discussion Forum
cub cadet motor - help identify
gaschad
07-16-2005 23:33:19
I have a cub cadet motor (on word from previous owner). It and the wiring harness seem to match what I can find from diagrams.
The serial plate is missing. How else can I identify the size and year of the motor?
I can post pictures if needed.
Dr.EVIL
07-18-2005 07:46:00
 Re: cub cadet motor - help identify in reply to gaschad, 07-16-2005 23:33:19
Number of head bolts & oil pan shape are the easiest ways without tearing the engine apart. K-161/181 7 & 8 Hp engines have 6 or 7 head bolts.... not positive but about two too few to keep from blowing head gaskets. There were two different bores even from the factory, only difference between the two was 1/4" longer stroke on the K-181. K-161 in the 1961 to 1963 Cub Cadets had oil bath air cleaners. And the K-181 had a bit wider air filter than the K-161 if the housing hasn't been changed. K-241 (10 HP) K-301 (12 hp) K-321 (14 hp) all had nine head bolts. Oil pan on K-241 was flat on the bottom, all the others have a dropped sump for rod clearance due to the longer stroke. Flywheel and blower housing on the K-321 is HUGE compared to the K-301, And K-361 has ten head bolts.
gaschad
07-27-2005 19:44:37
 Re: cub cadet motor - help identify in reply to Dr.EVIL, 07-18-2005 07:46:00
Thanks. It has 9 head bolts. I need to check the oil pan, but I think its flat.
lucasss
07-17-2005 08:36:42
the bore size should give you your answer. lucasss
