Tractor Talk Discussion Forum
O.T. Dodge Caravan Sending Unit
doorman
07-18-2005 04:38:22
My wife's 2000 Caravan with a 3.0 engine has the oil pressure light coming on at an idle after driving for a while. Raising rpm slightly makes it go off. The engine does not "clatter", so I think the problem may be in the sending unit. Anyone have any similar experience ? Also, does anyone know where on the engine the sender is located? Thanks, doorman
Calif.Farmall
07-18-2005 13:57:10
 Re: O.T. Dodge Caravan Sending Unit in reply to doorman, 07-18-2005 04:38:22
Common Dodge problem, change the sending unit, should be right next to the oil filter. If you can get an OE one from Dodge it will be better quality than parts house. I put 3 of them in the wife's over the yrs. If the motor sounds good it probably is good. DAN
txgrn
07-18-2005 05:34:07
I'd say, before you do a lot of looking, change your oil and filter and use a higher viscosity oil. Just sounds like low oil pressure due to it being summer and it's associated heat loads and dirty low viscosity oil. (No offense intended on the dirty part but all our oil gets dirty sooner or later.)
Mark
doorman
07-18-2005 20:04:29
 Re: O.T. Dodge Caravan Sending Unit in reply to txgrn, 07-18-2005 05:34:07
Mark, no offense taken. Oil isn't too dirty , only about 2000 miles on it, but I noticed the last oil change sticker says 10w30 on it. I think I will try 20w50 when I change the oil, and I am also going to change sending unit. Thanks, doorman.
txgrn
07-19-2005 06:48:51
 Re: O.T. Dodge Caravan Sending Unit in reply to doorman, 07-18-2005 20:04:29
Now you're talking. FYI, I use 15W-40 truck diesel oil (80%)and Mobil 1 15W-50 (20%)in all my stuff except the lawnmower (air cooled) which gets 100% syn. That way I only have to stock 2 oils. Could just stock the truck oil, but the syn has proven it'self so in she goes. 100% syn I think is overkill and expensive.
Mark
