Tractor Talk Discussion Forum
how do you adjust the voltage regulator
chris sweetland
07-20-2005 08:54:07
on my to-20 i want more charge it isnt getting as much as i could get i want to adjust the voltage regulator but dont know how it is a 6 volt positive ground system thanks chris
RustyFarmall
07-20-2005 13:04:02
 Re: how do you adjust the voltage regulator in reply to chris sweetland, 07-20-2005 08:54:07
Does anyone know if the Fergusons used the 3 brush generator? If the Fergies used that system, then the third brush is what you want to adjust. Am I way off base here?
buickanddeere
07-20-2005 12:06:55
With the battery full charged with a portable 120V charger. Start and run the tractor for a while until the ammeter rate of charge drops back to "normal". Use a meter set to DC volts, not ohms, not amps and not AC volts. If using a digital set the diplay to read the numbers as E.G. 006.2V not 6.200V. Run engine at full rated speed with the lights on if it's diesel if it doesn't have a significant electrical load. Spark ignition engines will be drawing 3-4 amps through the ignition system. Set at 6.8V to 7.2V or 13.8V to 14.2V. Lower voltages for tractors used all day in warm weather. Higher for parade or cold weather use tractors.
Dan
07-20-2005 11:02:48
Most modern (foreign) 6v regulators are not adjustable. Some have a screw lock down on the points stop that moves the contact closer or further from the pickup. This is how you adjust how long these points stay together based on the pressure that is set to pull them apart. That said, I dinked around with my old 6v positive ground regulator on my Ford NAA tractor for weeks trying to get it right. I could get 6.2v or 7.9v - but for some reason nowhere in between... It is VERY difficult to do without the proper measurment equipment. Some old mom and pop shops may still be able to do it for you.
Good luck,
Dan
chris sweetland
07-20-2005 13:48:52
 Re: how do you adjust the voltage regulator in reply to Dan, 07-20-2005 11:02:48
while all of these responses had great info that i already new lets get back to the origanal question of how to adjust the regulator as i have a few jobs to tend to so i have to get it going
Bob
07-20-2005 16:53:57
 Re: how do you adjust the voltage regulator in reply to chris sweetland, 07-20-2005 13:48:52
First of all, if you decide to do this, procede at your own risk! It is a delicate procedure, not always successfull for the "inexperienced".
Before removing the cover from the voltage regulator, disconnect the battery. This will aid in keeping all the smoke in the charging system. After your attempt at "tweaking" the voltage setting, re-connect the battery, start the engine, and check the voltage again. NOTE: the presence of the metal cover MAY slightly affect the final charging voltage setting. Make your final measurement with the cover installed.
Of the 2 or 3 "units" in the regulator that look like relays, the one wound with the finest (lightest gauge) wire is the VOLTAGE REGULATOR.
In general, increasing the spring tension on the contact arm, holding it AWAY from the coil winding will increase the voltage regulator's "set point".
On older units, there is usually an adjusting screw to do this. On newer units, typically you have to bend the tab that the lower end of the little extension spring hooks on, a tiny bit, to increase tension on the spring. BE CAREFULL, a little increase of tension goes a long way! (A needle-nose pliers should work, or an old time mechanic will have a slotted tool to bend the tab with.)
If the system IS charging, and you just want to increase the voltage a litle bit, DO NOT monkey with any other settings, or adjust the point gaps.
Also, resist the temptation to push on any of the contact arms, especially the heavy-duty points on the cutout unit. If you do this with the engine stopped, the points will remain closed, "cooking" the generator and regulator.
A common setting for a 6 Volt system is 7.4 Volts.
chris sweetland
07-20-2005 19:13:15
 Re: how do you adjust the voltage regulator in reply to Bob, 07-20-2005 16:53:57
i want to get my volts at around 7 giver or take right now it goes from 6.2+/- to about 6.5 ish full theottle
Bob
07-20-2005 20:45:40
 Re: how do you adjust the voltage regulator in reply to chris sweetland, 07-20-2005 19:13:15
7.0 is too low.
chris sweetland
07-21-2005 06:35:04
 Re: how do you adjust the voltage regulator in reply to Bob, 07-20-2005 20:45:40
im not fussy i just want it more than 6.5v as long as im at or around 7 it will be fine for how i use my tractor
