Tractor Talk Discussion Forum
Standard or overbore engine kit-- which to use
Darren in TN
07-21-2005 06:46:43
Howdy, all.
I'm about to do an overhaul on an abused tractor (a Ferguson TO-30) and want to know what your opinions are on standard vs. overbore engine kits? This will be a working tractor on our farm, so I'd like it to last a good long while. The tractor isn't underpowered, so I really don't have any reason to go to an overbore kit unless it gives the tractor some advantage in regards to longevity (or some other advantage you guys know about.) In your experience is there any difference in how long an engine will last with either of the two kits?
Thanks in advance for your comments,
Darren
cdmn
07-21-2005 20:57:46
 Re: Standard or overbore engine kit-- which to use in reply to Darren in TN, 07-21-2005 06:46:43
I'm pretty sure the engine has replaceable wet sleeves.
Mike M
07-21-2005 18:48:19
I think some of those dry sleeve over bore kits may leave the sleeves out and run in the block.I'd check it out closer. I wouldn't want this as I'd rather be wearing out a replaceable sleeve. But if the overbore kit still used sleeves but offered more power I'd go for it. Never heard many complaints of too much power. Your tractor should have a water pump so it should cool ok. I was advised once not to put the soup up kit in a Farmall C that didn't have the water pump as it would over heat.I took this advice.
txgrn
07-21-2005 17:36:34
I have several tractors that are 30 to 40+ years old and over 2/3 still have their original rings. I doubt that they were hangar queens.
If it needs them put em in. If not don't do it unless you just want to. Boring is expensive and not necessarily a requrement. Depends on what you find when you get there.
Read the min-max specs in the service manual.
Mark
Coloken
07-21-2005 10:04:00
Havn't done an engine for years, but one of the reasons for an overbore set was it raised the compression ratio. This made the older low compression engines more adapted to modern gasoline. I can think of no reason to not go overbore, depending on the engine involved and that it doesn't "soup it up" too much.
Kennyp
1945 A
07-21-2005 07:58:16
Your machine shop should be able to tell you the condition of the bores, and that will tell you whether standard pistons/rings can be used or if you need to have the block bored.
Either way (standard or oversized) will work for a long time IF done correctly (bores straight/properly finished, etc.).
Only other advantage to oversized is more displacement. All things being equal (same head, carburetor, cam, etc) I don't know how much difference you'd notice in operation...
Good Luck on whichever way you decide!
