Tractor Talk Discussion Forum
no more spark!!HELP!!
K-9 Cattle Corp
07-24-2005 09:31:07
I have a B John Deere that I am going to pull this year. M pull is on Friday. I went to start it up, nothing, just crank,crank,crank. Pulled out the plug, no spark. Maybe the coil? What do you think?
P.S. If there is a homepage on this, just ignore it. Thats what happends when bad E-Mail come through. Thank You All, God Bless!
Sloroll
07-24-2005 10:45:54
 Re: no more spark!!HELP!! in reply to K-9 Cattle Corperation, 07-24-2005 09:31:07
First try cleaning the points (drag a dollar bill through them a few times). If that doesn't work file the points. No help? Then do the condenser and then coil. Cheapest fix to most expensive. Then go get some firewall/virus protection for your computer.
If you go into your computer accessories or tools (In program area of your PC) see if there is a "System Restore" program This will allow you to restore your computer to an earlier date before being effected by what ever crap got down loaded. This post will be deleted very soon I am sure.
old
07-24-2005 10:45:22
I'd first do a hot wire from the battery to the coil. If you have spark then you need to look at the wireing from the coil back to the switch. If you still don't have spark I'd check the points/condenser cap and rotor any one of them can/will casue that problem
