Tractor Talk Discussion Forum
Core housing, inner tube
bo
07-24-2005 16:26:33
Ok, where am I going wrong? I have calcium filled rears. A year ago, the inner tube valve was dripping. I bought from Napa a core housing that goes into the inner tube valve. Today, I see that it's dripping salt again. I replaced it with a new core housing with Shrader valve core.
Now the question....why did that shrader valve core get eaten up by the salt so quick?
The core housing and inner shrader core was for liquid filled tractor tires.
I have to assume that it wasn't stainless or brass shrader valve. Where do I buy a inner core that won't get eaten up?
Appreciate the help.
Mike M
07-25-2005 05:48:56
 Re: Core housing, inner tube in reply to bo, 07-24-2005 16:26:33
I had one leaking on our 4020 and it was the part up in the tube was eat up causing the new stem not to seal up. I made due by cleaning it up and drying it out and putting silicone sealer on it before screwing it in ,let dry and it last many years that way. Finally had both tubes changed and painted up the rims not as bad as they looked ,but the tubes were really bad.Put the calcium back in for weight as it is needed for the loader.
buickanddeere
07-24-2005 18:40:18
Time to drain that nasty salt. Better cast iron or even beet sugar or windshield fluid.
bo
07-24-2005 18:47:21
 Re: Core housing, inner tube in reply to buickanddeere, 07-24-2005 18:40:18
Yeh,, I'm pretty disgusted with it.
old
07-24-2005 17:50:45
Thats just how some places make them any more, I've had some last for years and others lucky if they make it a year. Some places just have cheap junk.
Jerry Cent. Mi.
07-24-2005 17:18:34
Did you try putting in a little more air. Sometime a little dirt is in the valve and some air will clear it.
bo
07-24-2005 17:33:51
 Re: Core housing, inner tube in reply to Jerry Cent. Mi., 07-24-2005 17:18:34
That's not it Jerry, the inner shrader core gets eaten up by the calcium chloride.
bo
07-24-2005 17:33:26
