Tractor Talk Discussion Forum
case 1370 injector pump
red erickson
07-25-2005 12:31:10
my 1370 with overhauled engine uses fuel like crazy since overhaul, I heard you could turn the fuel injector pump down but where is it and how do you you do it? as not even case dealers here in north dakota know, thanks for any help and have a great day!!! RED!
Bob
07-25-2005 22:21:19
 Re: case 1370 injector pump in reply to red erickson, 07-25-2005 12:31:10
Check pump timing.
There's no need to set the pump's fuel rate down, as it will only inject enough to maintain speed for a given load, UP TO the maximum fuel rate setting.
If you're not pulling it's guts out, it won't be at anywheres near max fuel rate, anyway.
D-C 741
07-25-2005 20:53:30
Try the Air Filters,they might be pluged /we had it happen to our 1170 once. the other think to check is your turbo, it might be bad [not able to run up to top speed.
c hess
07-25-2005 18:38:00
First does it smoke all the time while pulling?DOES IT RUN SAME RPM AS BEFORE? Are seals still on pump? Need more info. There is a place on rear of pump to adjust rate but you need to be somewhat knowegable about it before attempting to change it. it is behind cap with 4 bolts holding it on. cant imagine a dealer unable to help. would question his other abilities
