Tractor Talk Discussion Forum
CAT D8R TRANSMISSION FLUID CHECK
GARY THE H
07-25-2005 15:19:28
How do you check the transmission fluid level on a D8R??. The filler plug is located on top of the tranny case,but I cannot find a dipstick or plugs to see if the fuid level is correct or not.
JohnH MD
07-25-2005 18:22:22
 Re: CAT D8R TRANSMISSION FLUID CHECK in reply to GARY THE H, 07-25-2005 15:19:28
I don't know about the D8R but the D6H and R we have has a dipstick below and toward the rear of the machine from the engine oil dipstick. Hope this helps.
John
matthies
07-25-2005 17:28:12
I work with a 963 crawler/loader at work and there are sight guages/windows that you check with the engine running, and thinking they are on the right side while sitting in the seat. They're under the cab.
Larry NE IL
07-25-2005 18:49:00
 Re: CAT D8R TRANSMISSION FLUID CHECK in reply to matthies, 07-25-2005 17:28:12
dipstick, rear of engine.
