Tractor Talk Discussion Forum
Cold Carb Intake
Rob Byrley
07-25-2005 15:25:59
I have a older Case 1845 Uni-Loader with a Case 159 4cyl gas engine. While running, the upper section of the carb and the lower area of the intake manifold actually get cold, even to the point that condinsation starts dripping. What causes this area to get so cold while the engine is running in such a hot enviroment???
old
07-25-2005 15:50:02
 Re: Cold Carb Intake in reply to Rob Byrley, 07-25-2005 15:25:59
Thats just normal cause by the gas going from liquid to a vapor.
RustyFarmall
07-25-2005 18:31:50
 Re: Cold Carb Intake in reply to old, 07-25-2005 15:50:02
I agree, and it seems to get worse during high humidity weather.
old
07-25-2005 18:56:47
 Re: Cold Carb Intake in reply to RustyFarmall, 07-25-2005 18:31:50
Hey Rusty did you know the indians used that same sort of thing to keep cool. they would soak a banket with water and the wind would blow on it and cause it to ice up.
Mike M
07-26-2005 11:04:33
 Re: Cold Carb Intake in reply to old, 07-25-2005 18:56:47
Dang ! You must be OLD ?
old
07-26-2005 11:19:56
 Re: Cold Carb Intake in reply to Mike M, 07-26-2005 11:04:33
Nope just know a lot of things that will never do me any good lol
Mike M
07-27-2005 06:53:45
 Re: Cold Carb Intake in reply to old, 07-26-2005 11:19:56
Well at least your sharing them with us and maybe someone will put them to use.
old
07-27-2005 07:53:37
 Re: Cold Carb Intake in reply to Mike M, 07-27-2005 06:53:45
That may be true. Guess that is what happens when you spent a lot of time out at sea with nothing to do other then read books and learn things that may never do more then fill ones head with info. LOL
RustyFarmall
07-25-2005 19:02:27
Didn't know about the indians but I have done similar things just as an experiment and it does work.
old
07-25-2005 19:30:11
 Re: Cold Carb Intake in reply to RustyFarmall, 07-25-2005 19:02:27
sort of funny that the indians knew how to make ice before the white man lol
